okay, first let me assure everyone that I have everything wired & grounded correctly. The wires and ground are 100% absolutely not the problem. Okay, when I turn on the radio with my sub hooked up to my amp, all I get is some static, but static that actually moves the sub as if it were hitting deep notes. Now here's the funny thing. I removed the RCA's from the amp(so there is no signal from HU to amp) and the exact same thing occurred. Does anyone have any ideas. I'm assuming that it is the amp itself. Is it a bad ground within the amp?
AMP PROBLEM!!! HELP!!!
Eclipse 8443, CDT ES-620s in doors (Clarion APX401.2), IEK, CDT 6X in rear(HU), Image Dynamics ID10v.3D.4 in stealthbox(Clarion DPX1001.2)<br /><a href=\"http://www.sounddomain.com/id/larryfirebird33\" target=\"_blank\">http://www.sounddomain.com/id/larryfirebird33</a><br />borla cat-back, FTRA, whisper lidTags: None
^^^Eclipse 8443, CDT ES-620s in doors (Clarion APX401.2), IEK, CDT 6X in rear(HU), Image Dynamics ID10v.3D.4 in stealthbox(Clarion DPX1001.2)<br /><a href=\"http://www.sounddomain.com/id/larryfirebird33\" target=\"_blank\">http://www.sounddomain.com/id/larryfirebird33</a><br />borla cat-back, FTRA, whisper lid
Damn dude i dont know. I myself am having amp problems so i bought another amp.
I was gonna ask if the rcas are touching the power wire but i am confused.<a href=\"http://www.cardomain.com/id/maleet\" target=\"_blank\">1998 Silver Firebird</a> <br />Basic mods... nothing real special but it sure looks good!<br /><a href=\"http://www.maleetpobanz.com\" target=\"_blank\">maleetpobanz.com</a>
ITS POSSESSED!!!!! Your sub's gone insane man...
wut you do is take out the subs and put them in your fireplace and set them a blaze!
Hopefuly it will get ride of the evil spirts, once it has pull the sub back out of the fire and hook it back up.. SHOULD be good as new don't quote me on that tho [img]smile.gif[/img]
But for real did you disconnect your remote wire too? Its prob just your amp its broken.....
Good Luck!!!!
Did anything happnen to the amp leading up to this? Is it just with the radio? What happens with CD's?
Matt\'93 Red 3.4L Camaro<br />Engine: Jet II, Pacesetters, K&N FIPK, Accel Wires, Iridium Plugs, Flowmaster, ASP U/D, 180 Thermo, much more...<br /><br />\'98 Z28 Vert Triple Black A4 Stock for now<br />34000 Miles<br /><br />Not enough room in the sig for my stereo.
your getting induced voltage on the power line and its carrying over to the singal inside the amp,
1. the amp ground is bad
did you sand the paint off b/f you gounded?
2. the main gound for the car is coroded/bad and leting interferance from the engine area on you power wire.
or the amp has a "cold solder" and its ground is not perfectwww.turbov6camaro.com
1997 3800 Series II Camaro
It's when ever the radio is on, including CD's. Even with all the gains completely down it does this. I wish it were as easy as the ground, but it's the same grounding point as my other amp which works fine.Eclipse 8443, CDT ES-620s in doors (Clarion APX401.2), IEK, CDT 6X in rear(HU), Image Dynamics ID10v.3D.4 in stealthbox(Clarion DPX1001.2)<br /><a href=\"http://www.sounddomain.com/id/larryfirebird33\" target=\"_blank\">http://www.sounddomain.com/id/larryfirebird33</a><br />borla cat-back, FTRA, whisper lid
