Speaker / Amp recommendations - FirebirdV6.com/CamaroV6.com Message Board
  • Speaker / Amp recommendations
    I have a ThirdGen Camaro, I have Eclipse 51/4's in the dash, Eclipse 61/2's in the rear, and Boss Tweeters mounted just above the 61/2's. These are all running to a Interfire 4-Channel 900watt amp.
    Then, I have 2 Audiobahn 12's in a camaro style box, run to a Interfire 2-Channel 900watt amp.
    My problem is this, I do not get enough "Volume" out of this! Would you recommend another amp? Different speakers? Also, please see my post on "Issues with Tweeters".
    Thanks!
    [*]<b>Car: </b>1991 CHEVY CAMARO RS<br />[*]<b>Engine: </b> 3.1lt (191ci) V6 - MPFI<br />[*]<b>Stereo: </b> Alpine 7995 H/U | Eclipse 21000 EQ | BOSS IQ 3000w Amp | Crossfire AB 400watt Amp | 3 AudioBahn 12\" D/V Subs | Planet Audio 4x6\'s & 6x9\'s
    i would recommend trashing it all and starting over... i've never heard of interfire before, and i've never known anyone to actually buy audiobahn subs. one thing you'll learn with car audio, you have to pay for quality. you don't have to buy the most expensive stuff out there, but the cheap stuff is cheap for a reason--if it sounds too good to be true, it probably is.
    i would go for an alpine head unit, power four infinity kappa or alpine r series 2 way speakers off of it, and put some nice subs in the back... as far as an amp, i'd go with kicker, alpine, or rf... there are tons of decent subs out there that should make your car have a good deal of "volume"
