gm relay wiring questions - FirebirdV6.com/CamaroV6.com Message Board
  • gm relay wiring questions
    i have a package of 50 of these relays i bought for the purpose of sending strong current through them instead of regular switches. unfortunatly, i have no idea on how to wire these relays since they appear very different from regular ones. i have tried to get info on the part form the dealer's parts department but that failed. also, nothing online tells any info on it as far as i can see. the item is gm part number 25638146. it is a 5 pin relay with one small half pin as well.
    Here are some pictures:
    RELAY COVER
    RELAY CONNECTIONS
    INSIDE OF RELAY
    INSIDE TOP OF RELAY
    so, does anyone have any ideas on how i can wire this thing up?
    thanks,
    dan miller
    The pictures you provided don't work.
    What all do you plan on using the relays for? Are the pin layouts at all similar to the layout of a regular relay?
    2006 Tiburon
