doing a system - FirebirdV6.com/CamaroV6.com Message Board
doing a system
  • doing a system
    i decided i woudl do this right hte first time but after getting all of my equipment lined up ( a 4 channel xtant adn a mono amp, an eclipse 12 aluminum, and a milhouse box for it. along with some fozgate 6'5's he's in the sail panels and my jvc el cameleon headunit) i realized i have to componenets lined up and i need some help from you stereo gys that know more than i do. basically i have an xtant a4004 amp to push the 6.5 subs and the components doing the math that is a pretty good number of whats going to four speakers so i need a good and string components set so i can push the little guys as i hav e dubbed them and the mids and tweeters. adn ill post pics of the amp rack when it is done cause its original. sorry off topic. what are some good compnent speakers that will fit the standard that i have set?
    no fate but what we make<br /><a href=\"http://www.cardomain.com/memberpage/748167/1\" target=\"_blank\">http://www.cardomain.com/memberpage/748167/1</a>
    anyone
      i read your post, its confusing?
      What the heck are you asking?
        what is the best set of component speakers for an xtant a4004 amp?
          can anybopdy answer this question or is it just personal preference if so what is a compnent set that can handle at least 100 watts
            does anyone know this
              some CDT CL-61's will be perfect and sound awsome for your fronts. get them for like 150 for the set at www.thezeb.com
                There's no right or wrong answer to your question. Premier by Pioneer, Kicker, Alpine, Boston Acoustics, Rockford Fosgate, Focal, etc are all good brands. Your best bet would've been to find the speakers you liked, then find an amp to run it. Check power handling and sensitivy ratings and whether or not they will fit your doors(I'm asuming unless you use a set of Q-Forms kickpanels). I use Premier drivers and Kicker Amps in my SQ system in my Buick. They are quality speakers and not outrageously expensive like Focal and even Boston Acoustics. It all just comes down to your budget and what you want your system to do. Oz Audio made good stuff, but I'm not sure if they are around anymore. Diamond Audio and Image Dynamics would another brand(s) to research. Hope this helps.
                  thaks for the help guys i have decided to go with the mb quarts for my compnents i met a guy witha set powered by the type amp i am using adn the quality was exremly clear but i thank yo for the help and will post pics o fthe system when done thanks again
