i have two jl w3s in my back window in a custom box. And it has been very hot here lately and the other day my subs were on bu tnot even that high and they started making a wierd noise! so i checked it out and the foam part that surrounds the sub had came apart from the plastic of the sub! i think that its probably form the heat. im going to see if the place i bought it from will take care of it, but if not any suggestions?
sun/heat damage??
I had the SAME thing happen here in Houston, TX. THe speaker came apart from the Rubber circle thing, as a result of acouple years of heat. Luckly i bought a 5 yrs warranty on them, when i took then back, the stereo guy said "DAMN you must have a serious set up to do this damage "...lol, but i am sure it was from the heat. Anyways they replaced it noo problem, if you have no warranty, then there are some silicons that you can try, but the name slips my mind.
Hope this helps!Johnny M. <br />Black 95 3.8l CAMARO A4<br />Enough mods.....for now, hehehe!<br /><a href=\"http://www.cardomain.com/id/jpmabasa\" target=\"_blank\">My RIDE</a><br />\"I promise, it IS a v6!\"
