can i use a firebird headunit in my camaro if i have the monsoon ?? thanx
Firebird headunit in a Camaro will it work ??
I was going to do that for fun, just cause i thought my friends would get a kick and the firebird one has more stuff you can play with, but it is expensive, and i don't want to go diving for it. If you do it lets see some pics!2002 M5 camaro- VTR CAI, custom cat-back exhaust, battery compacitor, pullie, lowering springs, 32mm sway bar, cross-drilled slotted rotars. 1-10\" L7 in cubby.
Originally posted by Gallstaff:
Do any of the camaro headunits have equalizers?Yes, I know \"Artic\" should be spelled \"Arctic\". Can any of the mods change this?
You will have to somehow reuse the metal side brackets from your old Camaro head unit and put them on the new Firebird head unit. The metal brackets use to simply unbolt but now GM rivets them on I do beleive. Be creative, try and remove the brackets and reuse them or just make new brackets out of some thin metal.2006 Tiburon
