Alright, Thought I'd ask here to see if you guys have any suggestions for I fiddle with it tomorrow.
I have an in-dash LCD... wired to a brain unit in the back, then amps/subs/speakers blah blah.
Anyways, the problem is.. (just started)... I could be sitting there or driving and the whole system will just turn off, and then it'll cut back on after like 20 seconds or so. So I tried to double check the brain unit's ground was tight, that seemed fine, then I pulled the lcd screen out and made sure it was... Now when the system cuts off EVERYTHING cuts off, cd changer, brain unit, lcd the whole set-up. Could it be a fuse? short up front? Any idea's shoot them at me... Thanks a ton.
