is there a tutorial with pictures anywhere on the internet on how to install new door speakers? thanks in advance!
door speaker installation
Britney Spears is the HOTTest girl in the world!<br /><br />2000 Camaro 3.8L Y87<br />Flowmaster 80 American Thunder catback<br />Magnaflow Carsound Catalytic Converter<br />SLP Ram Air Cold Air Intake<br />Whisper Lid<br /> <a href=\"http://www.cardomain.com/id/freestylin59\" target=\"_blank\">http://www.cardomain.com/id/freestylin59</a>Tags: None
check this link, I have account access w/ scosche so i can get disassembly info from them.
http://www.scosche-cars.com/encyclop...icle_id=CT00741990 Firebird 3.1 T-Tops<br />Flowmaster exhaust<br />Kenwood MP 825 Deck<br />4\" Rockfords w/ tweet in dash plate<br />3 Way 6x9 Rockords in rear sails<br />1970 Camaro 350
http://shbox.com/page/windowmotor.html
A little more detailed. Real easy to do. First time I did it took me like 30 mins. Now I can take it off in about 3 minutes. When you are putting it back on, start from the top to the bottom. I always made the mistake of putting it on the bottom first. It has to clip on top so the bottom can lock. When you take it off, you will see what I mean. Good luck.98 Camaro V6
its a pita if you dont have this kind of a tutorial. the first time i took mine off i broke one of my bottom clips, doesnt effect anything thankfully. As for running the wire to the door, sometimes it needs a little bit of help. i have found that a clothes hanger with the wire taped on real well with ductape works really well but that just personal experience, im sure there are other ways. oh and if you do the clothes hanger, first undo the whole thing so its a wire and then bend the tip over and tape it. this prevents it from hurting the rubber hose that you run the wire though. good luck.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...8 hours ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....4 days ago
