window problem... - FirebirdV6.com/CamaroV6.com Message Board
window problem...
  • window problem...
    well...my passenger window started acting weird. If i wanna put it down, it'll go down then it stops after like a 1/4 the way down, so i gotta sit and wait a little and it goes down a little more, and i gotta keep doing that. This happens even when i gotta put it up. my uncle checked it for me, he's can fix most things, and he said the switch is fine and everything. he thinks that there is a capacitor or something that gives the window motor a boost of power and that could be going bad cause you gotta wait for it to charge up...
    so has anyone had this problem? do i have to change the motor? my friends Z28 is doing the exact same thing.
    Thanks for you help!
    TT BABY!!<br />98 Firebird Y87<br />Headers, Cut Out, 80 series Flowmaster, 160 thermo, SLP Fan Switch, Taylor ignition wires, Yank Torq Conv 2800, B&M Tranny Cooler, Transgo Stage 3, SLP CAI, Whisper lid, SLP STB, DD KB SFC, Billet Adj PHR & LCA. More coming!
    Sounds like you need a new window motor. Go to autozone and pick up one, just make sure it has a life time warranty. Here is an install guide:
    http://shbox.com/page/windowmotor.html
    Good luck, it isn't fun! [img]smile.gif[/img]
    2001 Black Z28 M6<br />Sprayed, slotted, geared and more~
      Extremely common on the f-bodies. Your window motor is on it's last legs. I'm pretty sure there's a walkthrough in our FAQ page at the top of the forum. [img]smile.gif[/img]
      Red 96' A4 Firebird
      Audio Audio and Autotek
      Check it out here!
        sweet, thanks a lot guys!
          Be sure to buy a replacement that has a lifetime warranty. Once you've gone through the trouble to replace it, doing it again later will be a piece of cake. I can guarantee that they will go out again, My driver's side is on it's third motor since 97.
          95 Camaro 3.4L A4<br />Bosch plugs/MSD wires, K&N FIPK , Magnaflow catback, hi-flo cat, B&M Shift+, Dee\'s spacer<br />Kenwood KDX-859, eXcelon Amps, Infinity Kappa 3-way doors and Perfect10 sub<br /><a href=\"http://www.cardomain.com/id/harbins95\" target=\"_blank\">Behold, the raw fury that is known as the 3.4!!!</a>
