Which sub? - FirebirdV6.com/CamaroV6.com Message Board
Which sub?
  • Which sub?
    Should I go with one Solo baric L5 12'' in a ported box or two pioneer 12's in a sealed box? Both will have 600 watts to them. I am looking for the most spl. Thanks.
    <blockquote>quote:</font><hr>Originally posted by FireFighter:
    Should I go with one Solo baric L5 12'' in a ported box or two pioneer 12's in a sealed box? Both will have 600 watts to them. I am looking for the most spl. Thanks.<hr></blockquote>
    Tough call, but I would advise against any pioneer sub. Someone posted that a single L7 (similar to L5) ported is louder than two of the same subs in a sealed box. If that is true, then I would say the kicker would be louder than those pioneer subs IMO.
    I have a guy running a single 12" L7 sealed and he says it pretty darn loud. Here's what it looks like
    Drop me a line if you need an enclosure.
    Steve
    www.subthump.com
    [ August 05, 2002: Message edited by: megabass ]</p>
      I'd bet that the L5 would probably be louder if you had the right box for it. Megabass makes some good stuff. [img]graemlins/thumbsup.gif[/img]
      <b><i>1999 Pewter Trans Am M6 - Stock for now...<br />296.6 RWHP and 310.6 RWTQ</i></b> -<i>SOLD</i><p><i>\"There are vast amounts of money to be made in the sevice of the Lord!\"</i><br /><i>1994 Green Camaro M5 - <b>SOLD</b></i><p><br /><b><i>Associate of VENOM-VI</i></b>
        OK thanks guys, IS their any difference between the L5's and L7's besides the power they can take? Like L7 = more SPL or what? I will probaly end up doing the L5 in a Ported box of 2 cubes, with 600 watts rms going to it. What do you think?
          Yeah, I think power handling is the main difference. The L7 is a little beefier. If you have a chance, I would get the L7 over the L5 though. I've seen 12" L7s for under $200. Let me know if you need a box like that. It's already 2.0 cubes and I can easily port it no problem. It'll hammer for sure.
          Steve
          www.subthump.com
            $200 new for an L7? Does port have to be tuned or anything?
              When the time is right for my system I will have you built my box. I already talked to you a couple of times about it. FireFighter8615@aol.com remember? Yea I love that single L7 setup but, it would be louder ported.
                Now I am thinking of two 10's I have no Idea what I want.
                  One 12 ported will be waaaay louder than two 10s sealed.
                    Now I am thinking of two 10's I have no Idea what I want.<hr></blockquote>
                    If the 2 10's are going to be sealed then I would say go with one 12 ported. First, one 12 will be cheaper then 2 10's... and second you don't have to power 2 speakers. You could just put all the power on one 12. You will also have much better low end with a 12 ported vs. 2 10's sealed. It's no contest between the two.
                    Red 96' A4 Firebird
                    Audio Audio and Autotek
                    Check it out here!
                      Well I think I will go with 2 10'' alpine type R's in a ported box with 300 rms watts going to each. How does that sound?
                        Well I think I will go with 2 10'' alpine type R's in a ported box with 300 rms watts going to each. How does that sound?<hr></blockquote>
                        Depends. What are you going to tune it to?
                        Red 96' A4 Firebird
                        Check it out here!
                          Hard to say, but your box size needs to be larger in order to be ported. What kind of watts can you get in bridged mode on that amp?
                            2 10'' Alpine type R's in a 2 cu ft ported box (1 cube per side) with 300 watts each. the amp bridged puts out 600 at 2 ohms.
                            My other option 2 12'' Alpine type R's is a sealed box with the same amp.
                            I want the most spl like I said before.
                              2 10'' Alpine type R's in a 2 cu ft ported box (1 cube per side) with 300 watts each. <hr></blockquote>
                              I don't think that is enough room to port those subs. Is that 1 cube before woofer and port displacment? I so, then it is definatly not happening. 2 12" sealed in 1 cube each would be much better in that case.
                              Red 96' A4 Firebird
                              Check it out here!
