I was just wanting opinions on running 4 10's in the back "tub" of the car. If you don't know what Isobaric is...it's running 2 10's in the box correctly, and then 2 other 10's mounted directly on top of the other speakers. (facing each other.) Reverse the polarity, and there ya go. Does anyone have any pics of this set-up in an f-body, or has anyone had any luck with a set-up like this? Lemme know! Thanks!
Isobaric?
Isobaric?
Red/Black 1995 3.4L Camaro<br />Cardomain page- <a href=\"http://members.cardomain.com/redblack95\" target=\"_blank\">http://members.cardomain.com/redblack95</a><br />--------------------------------<br />Mods: RKSport Low Profile Ram-Air Hood, RKSport Sport Wing, Rockford Fosgate Audio, K&N Filter, Flowmaster 80 Series, Red StreetGlow underbody neons/interior strobes, GTS Front/Back blackouts<br />--------------------------------<br /><a href=\"http://www.gafba.com\" target=\"_blank\">www.gafba.com</a> -Georgia F-Body Assoc.Tags: None
i believe this setup would be difficult because if 10" subs wont fit into the hole, fitting a backwards sub under the window is nearly impossible because of the issue of space.
Space isn't an issue. I'm putting the box in the tub in the back. I'm setting it low enough that I can clear the hatch when it comes down. The size of the box and everything will work. These speakers don't require a whole lot of air space. My question was...has anyone had experience with an isobaric "Clam Shell" set-up? And did anyone have any pictures of this set-up in an F-Body. Thanks.Red/Black 1995 3.4L Camaro<br />Cardomain page- <a href=\"http://members.cardomain.com/redblack95\" target=\"_blank\">http://members.cardomain.com/redblack95</a><br />--------------------------------<br />Mods: RKSport Low Profile Ram-Air Hood, RKSport Sport Wing, Rockford Fosgate Audio, K&N Filter, Flowmaster 80 Series, Red StreetGlow underbody neons/interior strobes, GTS Front/Back blackouts<br />--------------------------------<br /><a href=\"http://www.gafba.com\" target=\"_blank\">www.gafba.com</a> -Georgia F-Body Assoc.
JL has a pretty nice write up on this.
http://www.jlaudio.com/tutorials/isobarik/index.html
Read it, then decide if you want to go that route or not. I think you'll change your mind.
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.2 days ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...4 days ago
