Anyone go any clues where I can get something or what to do to boost my radio reception? I can hardly pick up some stations that I know I should be able to and theres no chance in hell I'm getting them in if it's raining. I have a Kenwood Head Unit if that makes any difference. [img]graemlins/dj.gif[/img]
FM reception
Did you install your Kenwood head unit or did you have someone do it for you? .If someone did it for you, pull the Kenwood out of the dash and see if they used the antenna adapter. I've seen installers cut corners by wrapping black tape around the mini antenna plug that's in your car and shove it inside a standard antenna hole found on aftermarket head units. They make an adaptor from mini to standard for this so everything fits tight. Don't know for sure if that's your problem but I would start there first.2006 Tiburon
Put some foil on your antenna [img]smile.gif[/img]<a href=\"http://www.cardomain.com/ride/2038380/5\" target=\"_blank\">http://www.cardomain.com/ride/2038380/5</a> <br />pacesetter hi-flo cat, slp loudmouth 2 w/3.5 slash tips<br />Springtech lowering springs 1.75 drop<br />Hurst sts w/ short-throw stick<br />Not yet installed-pacesetter headers<br />Zexel-torson lsd<br />3.73\'s
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.2 days ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...4 days ago
