99 Bird High Beam Low Beam Conversion - FirebirdV6.com/CamaroV6.com Message Board
  • 99 Bird High Beam Low Beam Conversion
    I just got done doing a High Beam to Low Beam headlight conversion on my 99 bird. I switched out the low beam lights with high beam. The 2 headlights were only 24.00 from atuozone. I had to remove the lowbeam light wires from the black socket as they would not plug into the highbeam light. I used some heat shrink to cover the wire ends as the plug into the new headlight then put a dab of silicone around it to help with mositure. I might have to align my lights tonight as not to blind oncoming traffic. But there is a ton of difference now. Along with my driving light mod I should no problem seeing at night now. Has anyone else completed this easy mod? Sorry so long.... Sorry Mods you might want to move this to electronics.
    [ July 26, 2003: Message edited by: NtenseV6 ]</p>
    99 Midnight Blue Bird A4 Y87 TA Hatch,Driving Light Mod,Dual Highbeam Mod,Sequential Taillights,Molding&Emblem Delted,MAF Sreen Mod. 3:73 gears to come.
    I did this on my 02 bird, only I modified simple little bulbs with a soldering iron
    it makes a huge difference [img]smile.gif[/img]
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      pics is what we need
