Electrical Problems or Gauge Problems???? - FirebirdV6.com/CamaroV6.com Message Board
  • Electrical Problems or Gauge Problems????
    I was making a 3-hr. trip tonight and about 2hrs into the trip my "Check Gauges" light comes on and I see that my battery gauge is reading low, like 9 or 10 volts. Well thankfully my car got me home and I began doing some tests to see whats wrong. The battery seems to be holding its charge cuz I went to put it on the battery charger and its reading a full 12 volts. The car cranked up fine after I had already turned it off as well. So the alternator seems to be charging the battery up fine. I turned it off and turned it on again and let it run, no problems. I turned on pretty much everything in the car to see how it reacted with the load and the battery gauge dropped slightly but picked back up to 9 or 10 volts after one second. Im beginning to think its a strange gauge problem. Im gonna check any fuses tomorrow to see if thats the problem. Anyone have any suggestions. Im gonna get the alternator tested tomorrow just in case.
    *NOTE* A couple of days ago my car went to a Chevy dealership b/c the car was skipping. They hooked it up to their computer and ran some tests and found out it was a single spark plug wire that had went bad or fried. Today was my first time driving it since then. But it went for 2hrs of straight driving w/ no problems.
    <b>1998 Cayenne Red Camaro 3.8 A4</b><br />-Whisper Lid, K&N, manual fan switch, DEI 508D<br /><br /><b>FOR SALE:</b><br />-Whisper Lid<br />-PAC OEM-1 adapter<br />-GM Delco 12 disc CD Changer<br />-MTX 4250D amp<br />-Kicker Free Air subs<br />-DEI 508D Proximity Sensor
    I bet it's an alternator problem. But it could be the gauge itself. I just put a new voltmeter gauge in my car and its readings are quite different from the factory gauge.
    1995 3.4-Blackouts, 3 10\" MTX Subs, High flow cat, Faze voltmeter & air/fuel gauges Kenwood 800w amp,80\'s series Flowmaster, . ....more to come
      Thanks alot 95slowcar!! I had the alternator tested and sure enough it was only putting out 30 amps. I was actually hoping it was something simple like the alternator and not something more serious like wiring or gauge problems. Thanks again!!
        No problem man, glad it worked out for ya. [img]graemlins/rofl.gif[/img]
          A good troubleshooting rule: If it's a voltage problem when the car's running, check the alternator, if it's a voltage problem when the car's off, check the battery. Not always 100% right, but a good place to start.
            6 days ago
