flashers - FirebirdV6.com/CamaroV6.com Message Board
flashers
  • flashers
    i installed clear corners on my 98, then my flasher went out (emergency flashers still worked)
    i just replaced the flasher, and it is working correctly now... but the front signals do not flash...
    my drl's work, but no blinkers... did they go out when my relay went out?
    and, finally, what color wire is the blinker wire going to the bulb?
    thanks!
    White 1998 3.8L Camaro
    Home Ram Air / Free Flow Intake
    Drilled / Slotted Rotors with black painted Calipers
    anyone?
