i am about to hook up 2 amps, my sub amp 800 watts rms and a 4 channel amp 400 watts rms, i am running 4 ga power wire, when i get to the distrubution block do i run 4 ga to the amps or 8 ga, also should i run a big (80 amp) fuse then have a distubution block or have a block with 2 40 amp fuses on it???
distrubution block
8 would prally work to the 400 watt amp.. but u could run 4 to both and it wouldnt matter.. u'd be better off with 4 i think though1999 Black Pontiac Firebird <br />2 Rockford Fosgate P312D4 subs <br />Hifonics Brutus 1205d amp<br />Clear Sidemarkers<br />18\" Arelli Jovan Chrome Wheels
His amps will probaly except 4awg and smaller, I would run a 2awg or even 0/1awg from the battery back, more so if you are going to upgrade later.2005 Cavalier LS Sport M5<br /> <a href=\"http://members.cardomain.com/firefighter8615\" target=\"_blank\">http://members.cardomain.com/firefighter8615</a>
for the wire.....i would run 4 g to both amps and you should have 3 fuses. 1 fuse no more then 1 foot away from your battery and one fuse between each amp and the distrobution block...you can even buy a fused distrobution block. The way to know what fuese to use is: if amp 1 has a 40 amp fuse and amp 2 has a 60 amp fuse then the fuse by your battery needs to be 100 amps. then each fuse after your distrobution block should match the fuse on the amp your wiring to.99 camaro conv. 18in 100 spoke rims, body kit, ac delco iridiums, taylor 8mm wires, 2 12\' L7 soloberics with 1500 rms. I think im going deaf.<br /><a href=\"http://67.19.33.20:8080/sig/0G%20Car4.jpg\" target=\"_blank\">http://67.19.33.20:8080/sig/0G%20Car4.jpg</a>
I don't think they make a 140-amp fuse so use 150 for up front by the battery.
For the fuses in the distribution block: the amp with 2 40-amp fuses, you'll need an 80-amp fuse in the distribution block and the amp with 2 30-amp fuses, you'll need a 60-amp fuse.2006 Tiburon
