i am building a new box tommorow and it will be 2.5 cu.ft. I am building it on the hump right behind my rear seats. Not in the hole. I was wondering if it would be better to port it out the front back or top?
Box Help Fast!
fire the ports to the rear of the car for best response.99 camaro conv. 18in 100 spoke rims, body kit, ac delco iridiums, taylor 8mm wires, 2 12\' L7 soloberics with 1500 rms. I think im going deaf.<br /><a href=\"http://67.19.33.20:8080/sig/0G%20Car4.jpg\" target=\"_blank\">http://67.19.33.20:8080/sig/0G%20Car4.jpg</a>
Originally posted by CAMAROWIDBASS:
i came up with about 4 cubic ft before sub displacement.
What thickness of wood are you using?
Isn't there a "custom" box available already built that will hold a pair of either 10" or 12" drivers that are specifically designed to fit the Camaro and Firebird hatchbacks? Seems like I've seen them around. Maybe someone already has the specs for a 2x10 or 2x12 box. Cox if your box is only 11" high, you ain't putting 12" drivers in it. Unless the drivers mount firing upwards, I suppose.
I must admit, for such a big car I was horiffied to see the tiny space available under the rear hatch. I bought my son a box with a pair of 12" in it and the only place we could put it in the end was on the back seats.
Phil
