K I got it put in at best buy and now the antenna dosen't want to go all the way down, hell it sounds like the headlight motor when it went out. is the gear giving out? is it possible that the guy installing the stuff broke it?
got XM put in, antenna problem
95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------> <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>Tags: None
It may be just a coincidence that your power antenna is going bad. They shouldn't have even touched the power antenna, there's no need to.
The main drive gear inside the power antenna is probably still okay. The nylon teeth on the antenna mast itself is usually the first thing to strip out. I think GM sells just the mast itself (not sure of the part #).2006 Tiburon
