Will amp work with sub? - FirebirdV6.com/CamaroV6.com Message Board
  • Will amp work with sub?
    I have neither of these things but I am going to get a MTX Thunderform with 10" 6000 sub..
    Dimensions: 12.125" x 17.125" x 12.125"
    Weight: 13 lbs.*
    Power Handling: 250 Watts RMS*
    Sensitivity: 87dB*
    Enclosure Volume: .6 cubic foot
    Impedance: 4 Ohm*
    Will that sub work with a mtx thunder 6152 2 channel amplifier which has 325 watts brigded..
    The thing im asking is will a 325 watt amp be to much for a 250 watt sub? Will it blow?
    Derek <br /><a href=\"http://www.cardomain.com/id/dmiller_2005\" target=\"_blank\">2002 Metallic Silver Camaro</a><br />35th Anniversary
    Someone has to know!lol
      It will be fine. Are you still using the stock head unit? Just keep the gain low.
      How much are you getting that thunderform for? You might be better off getting an unloaded stealth from www.subthump.com and then selecting your own sub for it..... subthump also sells 12" versions.
      Red 96' A4 Firebird
      Audio Audio and Autotek
      Check it out here!
