What is the difference between the 200W and the 500W Monsoons? Are the head units the same and the 500W unit has an amp (mounted in the passenger-side rear wheel well)? Or am I crazy? I'm asking because I have the 200W unit and don't see any amplifier.
Update: I found the amp after all, it's tucked up in there pretty good. So I just want to know if the head units are the same.
[ August 13, 2003: Message edited by: mcjoslyn ]</p>
<b>Mike</b><br /><a href=\"http://www.cardomain.com/id/mcjoslyn\" target=\"_blank\">2001 Camaro</a><br />Light Pewter Metallic Convertible<br />AU0,A31,C60,DG7,F41,GU6,K34,L36,M30,T82,T96,UN0<p ><b>If it can\'t be expressed in figures, it is not science; it is opinion.</b>
1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
