10 w6 stealthbox question - FirebirdV6.com/CamaroV6.com Message Board
  • 10 w6 stealthbox question
    will a 10w6 fit in a stealth box from sub thumb. i have a jl 250/1 amp. i was goin to get a 10w3 but would i be better off with the w6?
    It will fit.
      yup...i swapped the 10" that came in my MTX stealth box...i think they're all made to fit correctly built boxes for that diameter
        Watch the 6 ohm coils on the W6. Just FYI since your only using one. [img]smile.gif[/img]
        Red 96' A4 Firebird
        Audio Audio and Autotek
        Check it out here!
          what do you mean the 6 ohm coils? will a w6 work with my jl 250/1 amp?
            The 10W6 has dual 6 ohm voice coils. It was intended to be ran in a trio at 1 ohm. If you are only using a single W6, you will have to run at 3 ohms nominal. Which, normally, would mean reduced power output from your amp.
            Will it work with your amp? Funny you should have the 250/1. The 250/1 is one of few amps that output the same amount of power regardless of the load presented. (From 1.5ohms to 4) So in answer to your question, yes. The 10W6 will work fine with your 250/1. [img]smile.gif[/img]
            Red 96' A4 Firebird
            Check it out here!
              haha! sweet! thanx alot man!
