Help me put together a system - FirebirdV6.com/CamaroV6.com Message Board
  • Help me put together a system
    Yes, i need major help, being new to the entire aftermarket stereo scene. I have about $600-700 give or take a few bucks, to put into a system. I need to know what is the best system setup out there you could make with these funds. I listen to mostly rock and rap.
    Help will be extremely appreciated!
    Be sure to read our FAQ section in the modifications encyclopedia. [img]smile.gif[/img]
    Rock and rap. Gotcha. $6-700. Ok, but a couple questions..... are you looking for EVERYTHING? I mean, are you replacing the stock headunit also? Already have an aftermarket headunit? You have t-tops? Would you be ok with having a regular square box in your trunk with maybe a single 10" sub? Or are you set on having something similar to the stealth box? The stealth is about $112 new in itself.... that's why I ask. Or maybe you could find some good deals on used equipment? Let us know about the above questions and we can make some recommendations for that price range.
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      deck $200
      4 infitity speakers $200
      2 infinity 12's $300
      Amp 200
      since that over, i would say on 12 for about 100- you can find infinty's and you be right there
      www.turbov6camaro.com
      1997 3800 Series II Camaro
        To answer some questions, i will be replacing the head unit. No T-Tops. I probably should have been more specific in saying that for about $600-$700 i need speakers, headunit, sub(s), and amp. Im ok with any type of sub boxes, just as long as they fit in the deep well of the trunk.
        Second, what other stuff will i need to accompany these?
          Whatever you decide on, make sure you buy it all online. You can find the same products for hundreds less than what stores charge, just do a little bit of shopping. I spent about 1k on my system (bought half online, half from stores) and could have brought it down around 750 if i had bought it all online. Good luck!
          Current:1962 Pontiac Tempest 4 cyl.<br />Future:1998 Pontiac Firebird v6
            check out my page for a nice and unique box idea...this was a 3-day custom build but you could make something like it youself easy...have fun [img]smile.gif[/img]
              i would check out elemental design, they are offering full system deals for around 800 and have everything but the HU. this is also all top notch equipment (better than infinity!), i would then recomend getting an eclipse HU and call it a day ;) . www.edesignaudio.com
                ^^ wow...good find [img]smile.gif[/img]
                  i know and with CDT helping ED design those components they now have one wicked total system. they compare those comps with the HD series from CDT.
