electrical problems... ticket! - FirebirdV6.com/CamaroV6.com Message Board
  • electrical problems... ticket!
    i got a ticket for not fixing my side marker colors to amber, and my left rear side marker was out...
    after inspection, and replacing all bulbs to new amber ones...
    the rear left one still does not work...
    any advice on that?
    also, since about the end of last year, my rear defogger wil only work for about a minute, then wont work for abou 10 minutes...
    it goes in a cycle llke that
    thanks for any help!
    White 1998 3.8L Camaro
    Home Ram Air / Free Flow Intake
    Drilled / Slotted Rotors with black painted Calipers
    Use a multimeter to see if you have power to the rear left marker. If you do, the socket is probably either faulty or just corroded with junk and not making good contact with the bulb.
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
