:mad: I cant find these damn adapters for my 6.5 inch speakers anywhere online and can't find them at Crutchfield or Sounddomain . Is there anyway I can make them fit by using some thin wood and cutting a circle or what should I do ? Im getting tired of not having a door speaker in my car .Thanx guys !
Damn Door Speaker !
Originally posted by tWiStEdBird:
I didn't need to use an adapter, my Poineer 6.5's went right in.
98 silver camaro t-tops , loaded<br />NGK plugs , Taylor 8mm wires , Optima Red Top .
they fit direct if u got the oversized ones.Black 1996 3.8 Firebird T5, SLP CAI, Pacesetter Ceramic Headers,160* t-stat, PCMforLess Tune, Flowmaster American Thunder catback, Car Sounds Cat, custom s-pipe, MSD coils and wires, NGK plugs, 3.42 posi rear, B&M Ripper, 245/50 BFG-G-force's
Originally posted by nda0602v6:
When you removed the factory speakers, there should still be a plastic housing/baffle left behind which is screwed to the door. Is it still there? That may be your problem if the plastic housing isn't there anymore.98 silver camaro t-tops , loaded<br />NGK plugs , Taylor 8mm wires , Optima Red Top .
Make new holes in the bracket like you said. Or just scrap the bracket completely and custom make your own out of 1/4" hardboard. (found at lowes or home depot). Its easy to do, all you need is the wood and a jig saw. Make the cutout for the speaker to sit in the wood then screw the entire wood/speaker assembly to the door.2006 Tiburon
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...11 hours ago
