My delima: I have the pioneer deh-p47d its the 1.5 din radio and it only has 1 pre amp outlet, however I already have it hooked up to my mono subwoofer amp 200watts rms x 1 but last week i went christmas shopping and bought myself a 45watt rms x 4. How can I hook up my other amp if my 1 pre amp outlet is already taken. Is there a conection that is made for these or do i have to buy a diff HU ???
1 pre-amp outlet
You can buy a RCA splitter if the preamp is RCA. You can get them from Radio Shack for pretty cheap. It would be a "Y" type connector.<b>Trucks</b> <br />\'05 Dodge 3500 Dually <i>Cummins Turbo Diesel</i><br />\'98 Dodge 2500 4x4 <i>360 V8 (Wife\'s)</i><br /><b>Toys</b><br />\'81 Chevy K10 <i>Stroker/Swampers/Custom Suspension/1-Tons/Beadlocks</i><br />\'99 Camaro Z28 <i>6 Spd, T-tops, Borla</i><br /><br /><b>Real trucks don\'t have spark plugs</b>
Do either of your amps have a pass thru RCA output? Some amps will have a set of RCA terminals for input, and a set for output which will allow you to run one cable from your head unit to amp 1, and then run another RCA cable from amp 1 to amp 2.
<blockquote>quote:</font><hr>Originally posted by MTMike:
You can buy a RCA splitter if the preamp is RCA. You can get them from Radio Shack for pretty cheap. It would be a "Y" type connector.<hr></blockquote>
I agree, this is the best way to go.2002 5-spd NBM Camaro
Details: www.1lev6.com
