I've never installed any type of speaker/amp combo before, only my headunit. I looked in the FAQ, but there seems to be only specific stuff in their, unrelated to wiring. I'm pretty much just looking for a diagram that shows how the wires go. From the headunit, to the battery, to the subs. I pretty much have no clue.
Here's my equip:
HU: Pioneer DEH-P6600
Amp: Viper D1200.1 Pic1 Pic2 1200W @ 1ohm
Subs: (2) Kicker L5 DVC-4ohm (wiring parallel/parallel)
Wiring: Knukonceptz Complete 4awg amp install kit link
-20 Feet 4 AWG Blue Kolossus Power Wire
-3 Feet 4 AWG Silver Kolossus Ground Wire
-One Waterproof Mini-ANL Fuse Holder with 120A Fuse
-One 5 Meter Klarity Kable Blue OFC RCA Cable with Built in Turn On lead
-20 Feet BLUE Klear Kable OFC 12 Gauge Speaker Wire
-2 Gold Plated 4 AWG Ring Terminals, 2 Gold Plated 4 AWG Spade Terminals
-6 feet Split Loom and wire ties
If someone could draw up a quick schematic in paint, that would be ideal. But I'm confused on a few things, which include...
1. So the speaker wires go from the amp to the box, and then from the box to the speakers?
2. The ground wire for the amp needs to touch something metal, while the power wire needs to connect to the battery?
3. Do I use the preouts on my HU (2x 2V @ 100ohms) and run the RCA cables from there to the amp?
4. How do I get the RCA cables from the front of my car, to the back, without them being seen? I have T-tops, so can't go through the headliner (not sure if this is how its usually done.
Thanks for any help, I hope you guys can help me through this so I can have my first install go as smooth as possible. Need to know anything else, just ask.
Here's my equip:
