Hi all check the faq section, still confused, i'll make it short for you all. Iam getting a 12" alpine type R tonight, it is rated at 4 ohms. Iam planning on getting an amp soon as well. My question is, do I need to buy a 2 ohm amp or a 4 ohm? I dont understand that at all, I try not to post unless im really confused, and well iam!!!!
amp/sub help
The 12" alpine type R sub is a 300 watts rms sub, so get an amp that will run 2ohms and give you between 300-400 watts, wire the voice coils in parallel and you will be good to go [img]smile.gif[/img]1995 Camaro 3.4 A4<br /><br />CAI,IAT Relocate
In the modifications encyclopedia. Diagrams on how to wire your subwoofer.
The Alpine Type-R comes in two versions. SWR-1242D and SWR-1222D I believe. One has dual 4 ohm coils and can be wired a 2 or 8 ohm load. The other has dual 2 ohm coils and can be wired to a 1 or 4 ohm load. I know it may sound confusing, but it's really not. It's really important that we are certain on which model you have before we can make a solid recommendation on an amp. [img]smile.gif[/img]
And yes, one 12" Type-R will bump along nicely. [img]smile.gif[/img]
And yes, one 12" Type-R will bump along nicely. [img]smile.gif[/img]1995 Camaro 3.4 A4<br /><br />CAI,IAT Relocate
Hahaha I know what you mean man. Life isn't cheap. [img]graemlins/rofl.gif[/img]
Dual voice coil just means that the sub has two voice coils instead of one. What does that mean to you? TWO PAIR of + and -'s. This increases wiring flexibility for the consumer. More options on how to wire the subwoofer(s) to the amp. With a one 12" dual 4 ohm sub, your choices are 2 or 8 ohms.
That's how you will want to wire your subwoofer to the amp. This will put a nominal load of 2 ohms on your amp.
So you will be looking for a monoblock (single channel) amp. One that does around 500W RMS into a 2 ohm load. So in the specs you're looking for 500WRMS x 1 @ 2ohms. Get it?
Here's a good example. The Audiobahn A8000T does 800WMRSx1@2ohms. Plenty for your Type-R. And for about $135 shipped. Many people hate on Audiobahn. They say that the amps don't output power they should etc. Well, I'll agree that they probably fall a little short. But I bet you still pull 650-700WRMS of clean power out of the A8000T. Plenty for you. Truth is, Audiobahn is king when it comes to quality vs. power vs. price.
