Sound Deadening Alternatives: - FirebirdV6.com/CamaroV6.com Message Board
  • Sound Deadening Alternatives:
    I've searched, but didn't come up with exactly what I was looking for.
    What are some alternative (to Dynamat) for sound deadening? I'm looking into B-Quiet since that's the only one that compares themselves.
    How hard is it to take out your interior, install, and put back the interior?
    2002 Silver Metallic A4 Firebird - All Options
    Hotchkis STB, Custom Madrel Bent 3" Exhaust, Pacesetter Headers, Whisper Lid, FT Ram Air, K&N Air Filter, D2S HID, Baer Rotors, !EGR, !MAF, 10% tint, Parrot CK3300
    Your Mom or My Dad?
    lots to choose from
    Products
    lots of info, just use the search feature for more about which one.
    Completely remove entire interior, depends, i can remove all panels, seats, console, carpet just under an hour. Just because i've done it before. I didn't remove the dash though.
    As long as you have all the correct tools you need in front of you so you don't have to look for them, it won't take to long. 13 mm , torx 45, flat head power/handheld, pryer thingy to help remove seat belts, i might be forgetting something else.
    1998 Rally Red Camaro
    Manual 5, T-Tops
    Ebony Leather Interior, Kicker Audio System
      www.soundsdead.com
      or
      Lowes product,.. Frost king insulation
      *Matt
        Look at them carefully, and read a few reviews if you can on some...
        A few require heat guns to apply *may or maynot be an issue*
        Some have a really strong asphalt smell.
        I have even seen a few that use a seperate glue...
        But in either case if you take a look around for a bit and just read a bit on them, you can generally find a few that work close to as well as dynatmat with a fraction of the cost.
        I have seen a few guys talking about fatmat here recently, might be a good idea to check back with them about how well it worked.
        I know Cascade makes a decent one, and Tsunami make a good alternative.
        1995 Camaro 3.4 A4<br /><br />CAI,IAT Relocate
          I've heard good things about SecondSkin.
          <b><i>Don\'t Ever Judge Me</i></b><br /><a href=\"http://www.cardomain.com/id/earnhardt132000\" target=\"_blank\">\'96 Firebird Y87 3.8L V6 5spd</a><br />--No mods as of yet, shoot me some ideas if ya want.<br />178,000 miles and counting
            I used fatmat its not to heavy duty witch worked good in a convertible i have had it in for about a week and a half and i still smell it for half a second when i open my door but by the time i sit down in my car its totaly gtone! works awsome on a cold day, little less effective in the how new mexico sun. ill get in my car in the morning befor the sun comes up and its quiet but then when i leave cl;*** at 2:30-3:00 its a lot hotter and its a little less effective.
            I used 80sqft in my floor board and 20sqft in my trunk i am ordering more for the rest of the trunk and the doors. i recomend if you want to do the whole car get 100sqft and start at the fire wall and work back. throw it asfar under the black rubery plastic where your feet go and on the tranny hump and even "i did" go on top of it if engine/drivetain noice is an issue and i used 2 layers on the hump along the pannanger side floor where the cat converter is and exhaust runs. my interior is quiet but trunks still load i am doing 2 trunk layers later.
              what have you heard about b-quiet?
              Your Mom or My Dad?
                http://www.sounddeadenershowdown.com/
                  thank you, that's what I was looking for!
                  Your Mom or My Dad?
                    how much sound deadening material do I need to do my whole car? Including hatch and door panels?
                    Your Mom or My Dad?
                      ide say atleast 150 sqft maby even 200-250 for multi layers in spots. it goes faster thin youl think. i used 100sq ft easy no doors and missed under 1 side panel and some spots in trunk and ran out!. need like 80 more for what all i want getting 50 for now soon..
