1/0 power cable is needed. but what amp alternator and any changes to the batterie? I also plan on runing 750w power inverter, and 1-2 LCD's. so i am woundering what i will need to suport all this power draining fun stuff! ! !PS2, Lapbop, you know
requirements for 2500watt system?
he quoted me a 200amp for 220 a few months back.....been told he does good work aswell! Click here!!
Depending on how you want to run it, you might want to consider dual alternators also, Phoenix Gold will custom make an alternator up to 300amp I think but they cost you your liver! Also don't forget I would use probably a 50 Farad Cap Bank, but run at least a 10 farad. Two three, batteries for certain!
Not sure where to get the pulley, never used a smaller one on my alt..1995 Camaro 3.4 A4<br /><br />CAI,IAT Relocate
Originally posted by CAMAROWIDBASS:
For storage purposes
And some/most high output alts will already come with a smaller pulley then stock. Cheap and helps their numbers look higher. Say a company designs an alt that does 80 amps AT IDLE. Now they swap out the pulley for a smaller one, (Which probably doesn't cost them anything in exchange) and now it does 95 amps at idle. Get it?
Are we talking 2500WRMS? What amps do you plan on using? I have more then that now and all I'm running is an Irragi H/O alt and yellow top under the hood. Been that way for some time. Headlights dim when I have it bumpin hard, but nothing under normal listening levels. Yes 1/0awg is probably a must. Post up with what amps you plan on using.
dont do a cap, its a waste of money. Instead of doing a cap do a battery.
850cca battery = 2,200,000 farads
For storage purposes, you'd need 2,200 1 Farad capacitors to equal the energy of your battery.
On top of that a cap can provide instant transfer of power, a battery is not capable of such. If you draw a solid 80 amps off your battery and switch it to 130amps on an instant you will get a very serious voltage drop for an instant, I have seen as bad as 10 volts flat on 90amp drawing amps off 2 Brand New Optima yellows, and a 115amp alt in a car that came with an 80 factory, and no headlights or other serious electrical items on.
I personally run a 50 farad for my currently 2 amplifiers. I draw a max of 120 amps for my system. Personally I choose the 50 farad bank because I have had it for awhile. You could get away with a 10 and it would make a world of difference.
That is also a better way of looking at it.
What is the total of the fuse ratings in your amplifiers, that makes all the difference. This watt rating on your amp requiring different cable size really doesn't exist. A class A amp can draw 80 amps of power and only put out 200 watts, where as a class D can draw 80 amps and put out 1000+ watts of power rms..1995 Camaro 3.4 A4<br /><br />CAI,IAT Relocate
2400 watt max.620w 2x20 amp fuses,980w 2x25 amp fuses and not sure think it will be 800w 2x20-25
total 130-140 amps . thinking 1 yellow top optima, 20fared cap, 180-200 amp alternator?
My convertible has limited trunk space and i dont think ill bve putting am extra batterie in thier unless it will fit behind the stealth box.
And yes the extra battery if you are having that severe of a problem will help, your amp was turning off because you were bouncing around 9-10 volts flat..... OUCH!1995 Camaro 3.4 A4<br /><br />CAI,IAT Relocate
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...3 days ago
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...5 days ago
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...2 weeks ago
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...3 weeks ago
