running wire UNDER car - FirebirdV6.com/CamaroV6.com Message Board
  • running wire UNDER car
    ok guys i am going to be installing my electric cutout friday, and i have ran the wire/switch to the back drain plug in the back seats, i see a channel under the car along the very edge i could put the wire up in there, but i dont really see a place to attach the wire, i am gonna put it in wire loom but how can i attach it to the car?
    Probably a bad idea to run anything exposed to the elements.
      uhh HTF u run a wire to the cutout then einstein!!!
        I thought you meant that you ran it to the backseats UNDER the car, and saw a channel under the car to put the wire in.....
          no i ran it under the carpet to the backseats, my plan is to run it through the drain plug, slice the plug, silicone it for a seal, the wire is already shrink wrapped or in some kinda gray tube thing, i am gonna zip tie it to the side of the channel to the cutout, it will be under the car for about 2 1/2 to 3 feet, and will be protected by shrink wrap and wire loom and will be zip tied to hell!! u think this will work?
            Sounds like the best you can do. I have a wire comin out that drain and running back to the inline fuel pump.
            \'98 Camaro V6<br />Appearance... pleasing<br />Performance... just a little extra air.
