Ok, I have this sealed box and I know that a ported box helps a sub put out a better bass quality, i was wondering if I could put a 2-3inch hole on both side at where i'm pointing to here:
Would it be alright for me to do this?
Also, I am upgrading my subs to two 12" Kicker Comp VRs Dual 4Ohm with 50-400w RMS(200 RMS per coil)
I wanted to know what amp I should get as in..2, 4 channel or mono? and because I don't under stand the whole 300x1 or 25x4 stuff, what should I be looking for as far as wattage goes? Thanks alot, im getting it all from crutchfeild.com probly if you have any links and will probably order it tonight.
