What size/type/make of speakers will fit in the stock Monsoon holes, and hook right up to the stock wiring? Thanks.
Replacements for Monsoon Speakers.....
Wife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350Tags: None
The stock speakers ( front and rear ) are 6.5". The hatch speakers ( which there is no reason to replace, I just unhooked them ) are 4" I think. If I remember right the stock rear speakers were 6 ohm, so any 4 ohm speakers should work without any problem. The fronts are a little different. They are technically component speakers with a tweeter and a woofer. The tweeter and woofer each have their own + and - signals. If you are just changing the speakers and not the amp or headunit then you *might* try splicing the two + together and the two - together. This really isnt that good of an idea, but there is an internal crossover in the monsoon amp so you wouldnt get any high end from the new speaker if you jsut plugged it into the woofer side. If you are going to replace all the speakers, why not buy a half-way decent amp. It would help the sound a lot. Also, a good headunit will make it sound like a different system...
But i degress... You should be fine with some good 6.5" speakers. In the front it would be a better idea to go ahead and buy a componet system that has a seperate tweeter.
I have rockford 6.5" in the rear, rockford 6.5" componets in the front, MTX 6000 sub, all pushed by a Orion 5 ch amp.
~Brian
[ April 11, 2002: Message edited by: DeathBuzzz ]</p>NEW 2002 Onyx Black SS Camaro<br />M6, leather, T-tops, Hurst shifter<p>sold: 1999 Pewter V6 A4 Camaro
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...4 days ago
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...4 weeks ago
