Installin An Amp In Camaro - FirebirdV6.com/CamaroV6.com Message Board
  • Installin An Amp In Camaro
    anyone got some instructions for installing an amp in a 95 camaro,I got an amp but no instructions.
    like which wires (color) to use for + and -
    The amp will have a + terminal which is positive.
    The - terminal is negative.
    The "rem" terminal is for the remote turn on lead, which goes to the thin blue wire on the back of your head unit.
    The RCA's go to your head unit.
    The speaker outputs go to the subs or speakers, just coordinate the + and - of the speaker outputs to match up with the + and - of the speakers.
      try to keep the ground wire as short as possible. Use the same gauge ground and power.
      Where ever you ground your amp to sand the area down first to the bare metal.
        dont run the power wire next to the RCA's either.
          Great site for help
          JL Audio has a good section as well.
          Another good link for all us fbody guys.
          Red 96' A4 Firebird
          Audio Audio and Autotek
          Check it out here!
