Hey my amp seems to make the speakers have a high pitched humm and increases as engine speeds increases. I put a bunch of filters in and still does it. Also i just blew my kenwood amp. Not related in topic though
Amp blew, alt noise bad
That buzzing your hearing thats going up and down with the RPM is actually you having a bad ground. you need to ground the amp's better and your problem will be SOLVED.2001 Black S10 Xtreme 4.3L A4<br />*RedLineVSix*<br />\"Throwin sparks, draggin frame\"
you should also check to make sure you don't any bad spots or uninsulated spots on your RCA(Signal) cables that go from the head unit to the amp, and make sure they are not running parallel with the power cables from the battery to the amp.Justin96Bird / Justin98TransAm<p>1998 Navy Blue TransAm<p>Whisper Lid<br />free ram air<br />K&N Filter<br /><a href=\"http://www.hhbc.com/justin96bird/index.htm\" target=\"_blank\">DynoMouth Exhaust</a><p><a href=\"http://www.hhbc.com/justin96bird/index.htm\" target=\"_blank\">http://www.hhbc.com/justin96bird/index.htm</a>
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...3 days ago
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...6 days ago
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...4 weeks ago
