farads/capacitors? - FirebirdV6.com/CamaroV6.com Message Board
farads/capacitors?
  • farads/capacitors?
    I'm buying this setup next week:
    -Audiobahn A12001DT Class D (1200 watts @ 1 ohm, 750 watts @ 2 ohms)
    -Audiobahn AWT12X 12" Linear Compression Subwoofer (2000 Watts RMS)
    -Custom Single 12" sub box w/plexiglass window (3.5 cubic ft)
    he recommened i get a capacitor, and ive heard that its good to have 1 farad per 500 watts. im running at 2 ohms, so techincally i have 750 watts running. i was thinking about getting the rockford fosgate CPCD10-03 capacitor, its good up to 1000 watts and its rated 1 farad. do you think this will do the trick?
    also, what exactly do they do?
    Dave:
    00 Supercharged Camaro - RIP
    97 Turbo Camaro - Sold
    or maybe an audiobahn ACAP7P?
    Dave:
      http://mods.firebirdv6.com/stereo.html#FBEAQ_1
      Red 96' A4 Firebird
      Audio Audio and Autotek
      Check it out here!
        Dave:
          I wouldn't waste your money on a cap, Upgrade the big 3 and you should not have any problems.
          [ February 18, 2005, 07:51 PM: Message edited by: FireFighter ]
            uh what?
            Dave:
              Originally posted by dmw319:
              uh what?
              Did you even read the link I gave you?
              Red 96' A4 Firebird
              Check it out here!
                I have a buddy that is really good with stereo stuff and has a good setup himself. He told me that you need 1 farad for every 1000 watts you have. I hope this helps.
                2000 Firebird 3.8L, GU6, G80<br />Maple Red Metallic <br />And the rest is all stock.<br /><br />SOLD:94 Firebird 3.4L<br />Flowmaster 80 Series
                  &lt;&lt;&lt; Shakes his head. Don't listen to that.
                    Caps are band-aids to try to cover up a poor electrical system. Big 3, if still have problems, a HO alternator will set you. If you need caps after that, you have a stereo so loud you can knock small children over when your bass hits.
                    94\' Quasar Blue Camaro - Gone<br />---New ride---<br />98 Silvermist GTP
                      what is this big 3 crap?
                      Dave:
                        Alt, Wires, and grounds i think
                        www.turbov6camaro.com
                        1997 3800 Series II Camaro
                          Battery Ground to chassis, Alternator ground to chassis and battery positive to alternator. Use 4awg or 0/1awg wire.
                            IT'S IN THE LINK I GAVE YOU!!!!!!!!
                            Red 96' A4 Firebird
                            Check it out here!
                              wow... if u couldnt find it there... y not google.com
                              the big 3 is a BIG part of your electrical system...
                              very easy to upgrade...
                              SEARCH
                              btw, how much u pick that amp up for?
                              you can find those brand new for under 300, hope u didnt pay much more than that!
                              White 1998 3.8L Camaro
                              Home Ram Air / Free Flow Intake
                              Drilled / Slotted Rotors with black painted Calipers
