Monsoon upgrade - FirebirdV6.com/CamaroV6.com Message Board
Monsoon upgrade
  • Monsoon upgrade
    Ok, break it down for me guys. I have a 99 3.8 Camaro with the monsoon CD player. When I replaced the front speakers I just bought some Pioneers from Wal-Mart, took off the door panel and found out there are 2 seperate connections for the speakers, the speaker only had one. Played with it for awhile and had to only hook up one or the other. What speakers are good for the Monsoon? Also, if I were to get an aftermarket head unit, which would be best to coincide with the Monsoon?
    Stephen Cruikshank<br /><br />Selling some stuff so all I have left is the FRA, !MAF Screen, whisper lid, Holley PowerShot, 3\" catback, and 160* thermo on the car<br /><br />I Practice Street S.M.A.R.T.S. - do you?
    We are working on a FAQ thread....
    until then....use this one. [img]smile.gif[/img]
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      thanx!
        Take the two wires that go to the coaxial tweeter
        and connect them to small tweeters that you install
        in the triangle in the door on the inside of the mirror.
        You can get self-contained tweeters (4 ohm) from
        many sources. Dont worry about crossovers as the
        signal is only high frequency anyway.
        the woofer is 2 ohm....thats a problem. Image Dynamics
        has a 2 ohm tweeter but they are very pricey....$189
        for a pair.....woofer only.
        Good Luck
        Phil
          Thanx Phil, I'll look into that!
            4 days ago
