Ok, break it down for me guys. I have a 99 3.8 Camaro with the monsoon CD player. When I replaced the front speakers I just bought some Pioneers from Wal-Mart, took off the door panel and found out there are 2 seperate connections for the speakers, the speaker only had one. Played with it for awhile and had to only hook up one or the other. What speakers are good for the Monsoon? Also, if I were to get an aftermarket head unit, which would be best to coincide with the Monsoon?
Monsoon upgrade
Take the two wires that go to the coaxial tweeter
and connect them to small tweeters that you install
in the triangle in the door on the inside of the mirror.
You can get self-contained tweeters (4 ohm) from
many sources. Dont worry about crossovers as the
signal is only high frequency anyway.
the woofer is 2 ohm....thats a problem. Image Dynamics
has a 2 ohm tweeter but they are very pricey....$189
for a pair.....woofer only.
Good LuckPhil
