battery terminal posts - FirebirdV6.com/CamaroV6.com Message Board
  • battery terminal posts
    most batteries i have seen on camaros, even the yellow top optima ones dont have battery terminal posts that i could use this with:
    do you guys know of a battery that has the post on top so that i could use this connector? its a rockford fosgate one for 0/1 gauge.. thanks
    Dave:
    00 Supercharged Camaro - RIP
    97 Turbo Camaro - Sold
    my optima had those on the top, along with gm side terminals
    White 1998 3.8L Camaro
    Home Ram Air / Free Flow Intake
    Drilled / Slotted Rotors with black painted Calipers
      Mine optima has both as well. Are you aure you're looking at the correct battery?
      Red 96' A4 Firebird
      Audio Audio and Autotek
      Check it out here!
        both mine, and my friends camaro doesnt have the posts on top. id have to buy a new battery. *shrug*
        Dave:
          gm only started using top post terminals recently, I guess after years of replacing batteries and battery trays made em smarten up a bit. optimas have side post and the standard top post. or if you want they sell connectors for side post batteries. www.knukonceptz.com has em, check it out.
          05' CTS-V
          00' Camaro - SOLD :(
            I have an optima so, I have both also but, if you go to your parts store, they sell thing bolt that replaces the stock one and gives you a threaded part with a nut on the other side. Its normaly called a side post adapter.
            I will go take a picture of mine.
            [ March 03, 2005, 05:43 PM: Message edited by: FireFighter ]
              ok thanks.
              Dave:
                http://memimage.cardomain.net/member...58_57_full.jpg
                http://memimage.cardomain.net/member...58_58_full.jpg
                  dmw319, yes, those side post adapters are great... however they will not allow you to use the terminal in your pic. :(
                  Red 96' A4 Firebird
                  Check it out here!
                    Here is an adaptor which converts the GM side terminals to a "post" terminal. This will allow you to use the Rockford terminal pictured. Walmart also sells the adaptor in a cheap non-gold version.
                    2006 Tiburon
                      Nahha! There ya go dmw. Exactly what you need.
                      Red 96' A4 Firebird
                      Check it out here!
                        awesome thanks a lot NDA.
                        Dave:
