gm only started using top post terminals recently, I guess after years of replacing batteries and battery trays made em smarten up a bit. optimas have side post and the standard top post. or if you want they sell connectors for side post batteries. www.knukonceptz.com has em, check it out.
I have an optima so, I have both also but, if you go to your parts store, they sell thing bolt that replaces the stock one and gives you a threaded part with a nut on the other side. Its normaly called a side post adapter.
Here is an adaptor which converts the GM side terminals to a "post" terminal. This will allow you to use the Rockford terminal pictured. Walmart also sells the adaptor in a cheap non-gold version.
