so im off for spring break andi want to try and get this done this week. I have a 12' punch with a sony 480W xplode amp. Any suggestions on how to build a box would be great. like dimensions and such. Ive already done a search and couldnt find much, plus the calculation sites ive been to are asking for all these figures that i dont know really anything about. any helpwould be great! thanx
custom 12' enclosure
im not looking for a stealth box but a full rear well enclosure. I was gonna indent the 12er in the center of the well and also indent the amp along with it next to the sub. I am not sure what material to use or what the dimensions of the enclosure should be....any helpwould be greatSLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
Do you have a model number for the Punch woofer you have? I'll see if I can find some parameters for you.
I would do like 96firebird311 suggested and build a simple square/rectanglur box. You should be able to use 3/4" MDF for the box, at least I was able to when I did a similar setup in a 3rd gen. Camaro I once had. If you want to indent "flush mount" the woofer and amp, one easy way would be to make a 1/4" or 1/2" thick trim panel covered in carpeting (with a cutout just big enough for the amp and also with a cutout for the full diameter of the sub) and lay it on top.
If you never worked with MDF, I would recommend predrilling the screw holes for the box itself and for the woofer mounting holes. MDF tends to want to split if you just drive the screws right in.2006 Tiburon
ok the model is rockford fosgate punchZ, i cant find a model number anywhere but yea so let me get this right here, i should build a square box and then cover the rest of the entire well flush with the top of the box?? im just trying to picture this and cant seem to do it. i want it to look relatively smooth on the outside, sorry im such a dumbass in this area, i can put an engine together but dont know jack about boxesSLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
From what info I could find, it looks like the 12" Punch Z came in either a single 4-Ohm or single 8-Ohm voice coil version. Power handling is 150watts RMS with a "sealed" box volume of (1.0 to 1.75) cubic feet. The ideal box size Rockford recommends is 1.25 cubic feet.
I don't know much about Rockford subs but it appears to be one of their entry level subs. Hopefully, you have the 4-Ohm version since you only plan on using one.2006 Tiburon
thnx for looking that up for me, so nda....is the area underneath the top of that box the exact box area u need? I am going to to want that same box only flush with the rear shelf, basically raised up. so should i just make a bx that is about 1.25 cubic inches and just cover the entire thing to make he well cover or what??SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
I outlined in red on the pic how big the box itself actually is under the carpeted panel. It's been so long ago but I think the box was only 1 cubic feet (was using a 12" MTX Black Gold sub).
Since you want your box up higher, I would just build a 1.25 cubic foot box and extend the sides of the box on the bottom as extentions to keep the box raised up to where you want it. Should only take a few hours to make something like that2006 Tiburon
