Kenwood KTC-H2A1 Install - FirebirdV6.com/CamaroV6.com Message Board
  • Kenwood KTC-H2A1 Install
    Hello, I'm thinking about getting a Kenwood KTC-H2A1 SIRIUS Tuner for the Maro. How do I install one of these? Is it easy or hard? Right now I still have the stock radio (not monsoon). Thanks for any help you can provide me with.
    2002 Black Camaro<br />A4
    You'll need the KPA-H2C "car docking kit" to use the KTC-H2A1 in your car. It uses a cassette adapter to send the music signals to your factory head unit and uses a cigarette adapter for power. Only wire you'll have to run is the antenna wire so its easy to install.
    You could also step up to the KPA-H2CFM "car docking kit" which eliminates the cassette adapter by using a wireless FM transmitter. This kit would probably be your best bet cause it would elminate wires going to your tape deck. Or if your factory head unit is a cd-player then you'll have to use the FM transmitter.
    2006 Tiburon
