I need one or two amps to power these 2 Infinity Kappa Perfect 10.D's and to power these Infinity Kappa 6.1 Component Speakers .
I'm looking at spending up to $250 or $300, possibly a lil' more for just the right amp(s). So, any suggestions on amps, companies, what my target power to each should be, etc. will be greatly appreciated.
Polo Metallic Green \'96 Camaro w/Y87 Performance Package<br /><a href=\"http://www.cardomain.com/id/greenmaro24\" target=\"_blank\">Corey\'s Camaro</a>
did u already buy these? I replied to your earlier post yesterday with a different suggestion. I definitely think the speakers i suggested are superior in every way.
Eclipse 8443, CDT ES-620s in doors (Clarion APX401.2), IEK, CDT 6X in rear(HU), Image Dynamics ID10v.3D.4 in stealthbox(Clarion DPX1001.2)<br /><a href=\"http://www.sounddomain.com/id/larryfirebird33\" target=\"_blank\">http://www.sounddomain.com/id/larryfirebird33</a><br />borla cat-back, FTRA, whisper lid
For that price range, you'll not find a better deal then a pair of these. Bridge one to the subs. The other will have PLENTY of power for those components.
If I get the Audiobahn A8002T and bridge it to run it to my pair of subs, it says the output would be 800W x 1 @ 4 ohm. Would that basically be equivalent to running 400W to each sub or 800W to each sub? Could someone clarify this for me?
Also, what are some other good companies to look at for amps?
Also, at what impedence do the Component speakers I mentioned regularly run at? Would this amp be a good one to power just my Infinity Kappa Perfect 6.1 Component Speakers?
Originally posted by The_Unforgiven: If I get the Audiobahn A8002T and bridge it to run it to my pair of subs, it says the output would be 800W x 1 @ 4 ohm. Would that basically be equivalent to running 400W to each sub or 800W to each sub? Could someone clarify this for me?
400WRMS to each sub.
Originally posted by The_Unforgiven: Also, at what impedence do the Component speakers I mentioned regularly run at? Would this amp be a good one to power just my Infinity Kappa Perfect 6.1 Component Speakers?
That will give each side 50WRMS. A respectable amount. [img]smile.gif[/img]
