I'm going to throw my PS2 in my car for the summer. I already have the power inverter cut so that I can hard wire it. My question is, what size fuse to put in between the inverter and the battery? Just to clarify a gray area...I just have to fuse the power wire and not the ground wire right? Thanks for any help.
if your going to hardwire it to the battery you MUST fuse it, or risk a the cable catching on fire.
And fusing a ground is no-no.
My car has GPS trackin\',traffic alert,its own phone #,PS2,screens. And What da H3ll,When I Turn da key it says \"You\'ve got mail\"..... <br />I swear and promise.. I\'ve had more cars then Charlie Thomas.. bounces in a Monte\' that hopped.. Pimped old skoo Blazer on Chopz, Today Its a Camaro at all da plya spots.
<blockquote>quote:</font><hr>Originally posted by MTMike: The inverter should have internal fuses, but you must always fuse for the smallest wire size in the circuit between the draw and the source.
I suggest running 8awg straight from the battery with a 50amp fuse or breaker just to protect the wire from catching fire.
-Mike<hr></blockquote>
Do I just wire the 8awg and the power wire from the inverter together?
