I did the fan switch mod and now if I hit the switch it will only turn on when the engine is off. The fans still turn on when the pcm turns them on with the engine running. I used the dark blue and the dark green wires on the passenger side. Are these the correct wires?? I used just one switch with an led on it which has three positions (high,off,low) and an add a curcuit fuse plug. Does anyone have an informative site or guide for doing this? Or an idea as to how to get it to run with the engine on also. ( I did a search and found many vague guides and message topics that were not informative).
fan works only when engine is off
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 day ago
