Is it possible to use a 4 channel amp to drive more then 1 speaker per channel without frying both the amp and/or the speakers? The amp I'm lookin to run is an RF501x; I'm pretty new to this I just want to make sure w/ you guys that know your sh*t. The amp will run 125 RMS x 4 @ 2ohms so If i wired up a pair of speakers in parallel I assume there shouldn't be any problems and each speaker on the channel will run at or around 60RMS. Does that sound about right or am I completely off, any suggestions would be greatly appreciated.
Originally posted by Mootzimus: If i wired up a pair of speakers in parallel I assume there shouldn't be any problems and each speaker on the channel will run at or around 60RMS.
That is correct. Check our FAQ page for more info. [img]smile.gif[/img]
Originally posted by CAMAROWIDBASS: if all speakers your planning on using are 4 ohm. Then you can wire up to 8 speakers. 2 per channel.
Actually.... if you wanna split hairs... :D ... I could wire a thousand speakers to one channel. They would each get .12WRMS....but that's besides the point. Just getting the point across. [img]smile.gif[/img]
