amp blowing fuses - FirebirdV6.com/CamaroV6.com Message Board
amp blowing fuses
  • amp blowing fuses
    my amp has gone through 2 pairs of fuses now lately... it has 2 20 amp fuses on the amp.. i cant figure out why its doin it.. i relized tonite that it was on hpf instead of lpf so i switched it over to lpf and turned it up a good bit and the song was over and on the next song there was no sound coming from the subs... i got home and changed the fuses to see if that was it and it started playin again after that... any ideas? thanks
    1999 Black Pontiac Firebird <br />2 Rockford Fosgate P312D4 subs <br />Hifonics Brutus 1205d amp<br />Clear Sidemarkers<br />18\" Arelli Jovan Chrome Wheels
    are you sure your not running the amp to hard at to low of a ohm? because it could be come unstable and blow fuses, i had an amp that did it once because the way the sub was setup for 2ohm and the amp was only for 4ohm went through fuses right and left.So i got rid of it lol
      i dont know... my subs are dvc 4 ohm and my amp is 4 ohm
        how do you have your subs wired to the amp?
        2006 Tiburon
          i dont remember to tell the truth.. i dont think they are parallel...that would put them at 1 ohm i guess? and series/parrellel i dont remember what that would make them but i think thats how they are..
            well if your amp is only stabl at 4 ohm and your goin down to 1 ohm i believe it would blow fuses like that correct ? get a 1 ohm stable amp and u'll be fine
              Yes, Series/Parallel is how they should be wired.
              2006 Tiburon
