new speakers not as loud as stock - FirebirdV6.com/CamaroV6.com Message Board
  • new speakers not as loud as stock
    I installed new 6.5" pioneers into the doors and they are not as loud as the stock speakers. How come?
    Britney Spears is the HOTTest girl in the world!<br /><br />2000 Camaro 3.8L Y87<br />Flowmaster 80 American Thunder catback<br />Magnaflow Carsound Catalytic Converter<br />SLP Ram Air Cold Air Intake<br />Whisper Lid<br /> <a href=\"http://www.cardomain.com/id/freestylin59\" target=\"_blank\">http://www.cardomain.com/id/freestylin59</a>
    DO you have a monsoon sound system?
      yea
        Monsson sound system runs off a 2 ohm system, while 98% of the aftermarket speakers run off a 4 ohm system so they are not compatible and do not sound right.
        I know its a pain in the ***... my front doors are both blown.
          so if i buy a new head unit, will my system run at 4ohms?
            your system is running at 4 ohms now, if you installed the pioneers.
            4 ohms = 1/2 the power of the 2 ohms stock.
            Ryan.
            1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
              yes
              www.turbov6camaro.com
              1997 3800 Series II Camaro
                Originally posted by viper04af:
                </font><blockquote>quote:</font><hr />Originally posted by Freestylin59:
                yes </font>[/QUOTE]how, without bypassing the monsoon amp, with new wire?
                  Originally posted by slow:
                  </font><blockquote>quote:</font><hr />Originally posted by viper04af:
                  yes </font>[/QUOTE]how, without bypassing the monsoon amp, with new wire? </font>[/QUOTE]Freestylin59:
                  "yes"= running new wire (bypassing monsoon amp) from new head unit to your new 4-ohm speakers.
                  2006 Tiburon
                    Yeah you have to bypass the amp for this...
                      does anyone have a diagram of how the monsoon system is wired throughout a 2000 camaro?
                        http://www.houston-f-body.org/tech/monsoon/Camaro.htm
                          im being told on other message boards that most head units only put out around 20-25 RMS so it wouldn't be enough to run the pioneers. Is this true? If i just run it through the monsoon amp, will it sound better?
                            y you have to buy pass the amp?????? buy a deck with preamp outs and there you go ??
                              Your stock door speakers were (2-ohms). The Pioneer speakers you now have in the doors are (4-ohms).
                              If you wire the Pioneer speakers up to your cars factory (Bose/Monsoon Amp), the factory amp will see a (4-Ohm) load thus only being able to put out roughly "1/2" of its rated power. (This is why your new Pioneer door speakers are only "1/2" as loud).
                              For the factory (bose/monsoon amp) to put out its "full" rated power, it needs to be presented with a (2-ohm) load. (This is why the factory door speakers were (2-ohms).
                              If you feel the RMS power from an aftermarket head unit isn't going to be enough power for your Pioneers, you may want to use an aftermarket amp just to drive the door speakers.
                              2006 Tiburon
