I need to know two things.
1)How do I get the covers off(they apear to be melted on can get side 4 poped out but not top or bottom)
2)Door panel not attached at bottom center, how do I get that back on(maybe I'm just stupid but I can't figure it out).
The speaker grill should be hot glued on at each tab. Don't be afraid to give it a strong tug; it will come off.
If the door panel tab has come out, then you'll need to remove the three screws at the armrest that secure the entire door panel. Then you need to lift the whole assembly up and remount it.
Is English your first language?
╓<br />║ Matt M<br />║ <a href=\"http://home.austin.rr.com/morrism/3800/sunset_logo2.jpg\" target=\"_blank\">Down with the Sixxness</a> <br />║ Polo Green 1995 3.8 Camaro<br />║ intake, cat, catback, shocks, 3.42\'s, and 12\'s in the trunk<br />╙
alright so just give a good tug and they come off.
I'll try that later.
Door panel tried that already can't get it to slide back on right. it's a 98 camaro and I'm tryin to fix all the crap that my dad broke with it. Is there some trick to getting the bottom tab re-engaged.
4 days ago
