has anyone done this and how i know there are some company's taht sell kits for it but im confused on how it actually works so if anyone has done this sahr ethe wealth i did a search and came up empty handed
battery relocation
Though I've never done it, relocating the battery is just a matter of extending the length of the main battery wire and making sure the battery itself is securly mounted wherever you locate it. If locating in the trunk, you'll need to use thick guage wire like 2-awg or thicker. Hope this helps2006 Tiburon
waht about the other wires in the on the terminal there are three going into it
under the hoodno fate but what we make<br /><a href=\"http://www.cardomain.com/memberpage/748167/1\" target=\"_blank\">http://www.cardomain.com/memberpage/748167/1</a>
Under the hood, you could use a 'distribution block' to tie all 3 of the (+) wires into the new thick (2-awg or thicker) wire.
Distribution block2006 Tiburon
your pretty much going to need 0 gauge which is very expensive, i paid about 120 for my 0 gauge wiring kit.
I know 12secv6 has his battery in the back but he put it back in the front BC his car would have trouble cranking.
Also if your going to relocate the battery to inside the car your going to have to get a sealed battery like an Optima.
And make sure you get THICK ( 0 gauge ) wire to get it back to the front of the car.96 White M5 Camaro. Manual everything. Magnaflow cat, dynomax dual outlet axle back. Swapped to a disc rear with 3.42s and a torsen differential, kyb gr2 rear shocks, moog rear endlinks.
Originally posted by MegaHertz:
</font><blockquote>quote:</font><hr />Originally posted by CAMAROWIDBASS:
And make sure you get THICK ( 0 gauge ) wire to get it back to the front of the car. </font>[/QUOTE]venting it to the outside means drilling a hole somewhere under the car, which in time cant be too good.
