i have the Delco system in my car. i want to install a new HU , Amp, and subs. i have the stuff in my garage. i did a search and just got more confused on how to install it.
is the anywere i can get a wiring diagram for the Delco from?
i have a 96 firebird, if anyone has installed one please help.
You should be able to get a wiring harness adaptor at any stereo shop. That way you don't need the diagram. It plugs in between your car's factory harness and the new HU. While you have the HU out, you should run your RCAs and your amp remote turn-on lead. Sometimes, but not always, that is marked on the harness. I wired my remote to the blue and white power antenna wire since I don't have the power antenna. Let us know if you have any other questions like running the amp power wire [img]graemlins/burnout.gif[/img] Let me know if you need a box for the subs?
Ok here is the deal i hook up all the wires to the harness and the harness said i must buy something else (for bose/premeim sound systems) that goes between the harness and the HU.
I hook up all the wires and there was one orange wire that was unused on the harness.
I am getting sound from the back speakers and the front speakers, but no sound from the middle. Also the sound is very low and distorted.
There was a second smaller wiring harness that came out of the stock HU with 5 or 6 wires.
i want to get it so that the HU runs the speaker and the amp runs the sub since it is only a one channel amp with a one ohms independency.
Ok i did the power antenna thing and it work and since my antenna motor is broken no harm done to that piece.
Now the subs and amp work but the sound is still distorted and when i turn it half way up i can hear the slightest sound. when i turn it up to the max it still has very low sound.
even the sub are distorted and low from what little I can hear of them.
pleaeaeaze help [img]graemlins/crybaby.gif[/img] [img]graemlins/crybaby.gif[/img]
